![]() | Home > Td5 > 2003 defender td5. Smoke |
Sounds like over fuelling, has the wagon had a remap? If not it could have a slight boost leak. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
divethedeep Member Since: 17 Sep 2014 Location: sussex Posts: 32 ![]() ![]() ![]() |
Just wanted to add. If landrover has sat ideling for a length of time smoke seems worse
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 161 ![]() ![]() ![]() |
It's also possible:
1. MAF issue 2. copper washer at the injectors 3. injector wear and tear 4. turbo issue 5. driver demand (throttle pedal issue) 6. leaking turbo hoses 7. stuck EGR 8. intercooler requires a flush or replacement 9. oil in the ECU The defender has migrated, leaving the owner behind. |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5982 ![]() ![]() |
Has it always done this? Just started? Worse when hot/cold?
Have you tried driving it with MAF disconnected? Checked the air filter? Andy |
OsloBlue Member Since: 14 Jul 2018 Location: Essex Posts: 825 ![]() ![]() ![]() |
The fact that it gets worse the longer you idle sounds like a temperature issue. Is the smoke having a blue tint? Wheres your coolant level? I'm on IG: https://www.instagram.com/osloblue42/
Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html ![]() |
It’s had a new maf fitted. (Genuine) Don’t know about cold as drive carefully when engine cold but definatlly hot New air fitted a month ago |
Could be a leak in the intercooler or its hoses. They show up worse once they have go warm, as they become softer.
mturri Member Since: 13 Jul 2010 Location: All over Posts: 33 ![]() ![]() ![]() |
Also check your turbo-to-intercooler & intercooler-to-intake manifold hoses for internal delamination (causing air deprivation under medium to high boost conditions).
Have access to live readings via Nanocom or similar? 24 yrs of Td5 ownership D110 Td5 MY06 fully tuned up ex-D2 Td5 MY04 Auto ex-D110 Td5 MY00 ex-D2 Td5 MY00 ex-D2 Td5 MY99 ex-D1 300Tdi MY89 ex-D90 200Tdi MY87 |
