![]() | Home > Maintenance & Modifications > Std height comfy spring options ? |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
I think alive do standard height comfort springs now?
You could always try the softest RRC front spings. 130lb/in I think vs 225 on the defender I believe ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
MJN110 Member Since: 18 May 2015 Location: North Yorkshire Posts: 380 ![]() ![]() ![]() |
Alive have STD height comfort springs listed on there website now. 2016 Defender Landmark 90
2005 Defender CSW TD5 90XS |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3750 ![]() ![]() ![]() |
I’ve got the alive standard height springs, and if your local you are more than welcome to come and try. I went with the springs and bilstein B6 dampers as the old ones had done a bit. The difference is night and day. On road comfort is superb and off-roading ability also seems improved.
LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 886 ![]() ![]() ![]() |
I run LR 110 fronts/Disco rears all round on my 90. Had them originally with the standard dampers which improved the ride considerably.
Have since change the dampers to bilsteins which has stiffened the ride up a bit and compromised some comfort but I can now throw it round roundabouts. Got the brand new Lr take off springs for £100 delivered for the set. They’re Progressive springs too ![]() |
2010Blackdefender90 Member Since: 07 Jan 2018 Location: London Posts: 562 ![]() ![]() ![]() |
I have the 1 inch Alive lowered comfort springs, but have the spring isolators top and bottom, which restores ride height, and provide zero noise transmission to the axles and chassis. Night and day
Last edited by 2010Blackdefender90 on 23rd Feb 2019 10:34am. Edited 1 time in total |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2490 ![]() ![]() ![]() |
LR spring isolators are about 10mm thick when fitted. Puma 110" SW
I too have the isolators
![]() I’d say 10mm maximum, more like 5mm each with the car weight on them |
Moneypit Member Since: 27 Feb 2018 Location: North Yorkshire Posts: 271 ![]() ![]() |
Anyone have the part numbers or a link for the spring isolaters. Thanks
I used the standard isolators on the top / bottom on the rear, disco 2 isolators on the front tops and standard on the bottom...
Anr2938 should work top and bottom... |
BogMonster Member Since: 05 Feb 2008 Location: Stanley Posts: 403 ![]() ![]() ![]() |
The ones I always used are ANR2938 --- 2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi |
Daisy90 Member Since: 01 Feb 2015 Location: Hampshire Posts: 845 ![]() ![]() ![]() |
Thanks all,
I have ordered a set from Alive ![]() Will report back once fitted |
Just got an Alive 110 comfort spring set off T'bay for £201, roughly half I was about to pay. I'll report back once I've fitted them
