Home > Maintenance & Modifications > Std height comfy spring options ?
Daisy90
United Kingdom 2001 Defender 90 Td5 SW Alveston Red
Hi all, finally able to get the 90 worked on again,
I'm after some std height springs for a 90 CSW 51 plate,
I looked at alive options, as they got great reviews but there all lowered as far as I can see ?
Ideally looking for some progressive comfy ride std height options if anyone knows of any ?
Th 90 is becoming more n more std again, as usually just trip uncles to work n back these days, hence removing winch etc,
Thanks for recommendations in advance Thumbs Up
Post #760072 21st Feb 2019 10:28pm
grafty99
I think alive do standard height comfort springs now?
You could always try the softest RRC front spings. 130lb/in I think vs 225 on the defender I believe Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #760074 21st Feb 2019 10:30pm
MJN110
United Kingdom 2016 Defender 90 Puma 2.2 Landmark LE Montalcino Red
Alive have STD height comfort springs listed on there website now. 2016 Defender Landmark 90
2005 Defender CSW TD5 90XS
Post #760081 21st Feb 2019 10:58pm
Co1
I’ve got the alive standard height springs, and if your local you are more than welcome to come and try. I went with the springs and bilstein B6 dampers as the old ones had done a bit. The difference is night and day. On road comfort is superb and off-roading ability also seems improved.
Post #760108 22nd Feb 2019 7:17am
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
I run LR 110 fronts/Disco rears all round on my 90. Had them originally with the standard dampers which improved the ride considerably.
Have since change the dampers to bilsteins which has stiffened the ride up a bit and compromised some comfort but I can now throw it round roundabouts.
Got the brand new Lr take off springs for £100 delivered for the set.
They’re Progressive springs too
Thumbs Up
Post #760146 22nd Feb 2019 11:45am
2010Blackdefender90
United Kingdom 2011 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
I have the 1 inch Alive lowered comfort springs, but have the spring isolators top and bottom, which restores ride height, and provide zero noise transmission to the axles and chassis. Night and day
Last edited by 2010Blackdefender90 on 23rd Feb 2019 10:34am. Edited 1 time in total
Post #760177 22nd Feb 2019 5:29pm
MK
LR spring isolators are about 10mm thick when fitted. Puma 110" SW
Post #760199 22nd Feb 2019 7:23pm
LandymanStefan
I too have the isolators Thumbs Up
I’d say 10mm maximum, more like 5mm each with the car weight on them
Post #760236 22nd Feb 2019 9:50pm
Moneypit
2004 Defender 110 300 Tdi HT Fuji White
Anyone have the part numbers or a link for the spring isolaters. Thanks
Post #760278 23rd Feb 2019 12:33am
2010Blackdefender90
I used the standard isolators on the top / bottom on the rear, disco 2 isolators on the front tops and standard on the bottom...
Anr2938 should work top and bottom...
Post #760304 23rd Feb 2019 10:33am
BogMonster
Falkland Islands 2015 Defender 110 Puma 2.2 USW Corris Grey
The ones I always used are ANR2938 ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi
Post #760367 23rd Feb 2019 4:30pm
Daisy90
Thanks all,
I have ordered a set from Alive Very Happy
Will report back once fitted
Post #760913 27th Feb 2019 4:47am
Moneypit
Just got an Alive 110 comfort spring set off T'bay for £201, roughly half I was about to pay. I'll report back once I've fitted them
Post #855689 12th Sep 2020 7:11pm
