Home > Technical > Transfer box change |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7685 |
Presumably there is a 1.2 box in there as std puma box? You could go 1 from Dave. Or bigger tyres height wise to trial it?
That won't sent it to the back will just change gearing. Atb t box might do it. I suggest you speak to Dave @ Ashcrofts on it. Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop Last edited by jst on 12th Feb 2019 12:57pm. Edited 1 time in total |
11th Feb 2019 9:52pm |
I suspect you need front and rear diffs to be of a similar spec. - either both ATB or both open. The torque is clearly finding the path of least resistance. Darren
11th Feb 2019 10:51pm |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6264 |
I think centre ATB is the answer. I believe that's what you get in the 70th edition and standard front / rear diffs?
12th Feb 2019 9:41am |
This is quite a nice problem to have. Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
12th Feb 2019 12:58pm |
billewizz Member Since: 16 Sep 2011 Location: north lincs Posts: 66 |
I stayed with the standard front to minimise understeer, but on roundabouts it does focus the attention, I would just like a little more mk2 escort than Vauxhall nova, a call to Ashcrofts looks like it’s in order. Thanks guys
12th Feb 2019 7:30pm |
