![]() | Home > Technical > Transfer box change |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8491
Presumably there is a 1.2 box in there as std puma box? You could go 1 from Dave. Or bigger tyres height wise to trial it?
That won't sent it to the back will just change gearing. Atb t box might do it. I suggest you speak to Dave @ Ashcrofts on it. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop Last edited by jst on 12th Feb 2019 11:57am. Edited 1 time in total |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
I suspect you need front and rear diffs to be of a similar spec. - either both ATB or both open. The torque is clearly finding the path of least resistance. Darren
| Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347
I think centre ATB is the answer. I believe that's what you get in the 70th edition and standard front / rear diffs?
This is quite a nice problem to have. Cheers
| billewizz Member Since: 16 Sep 2011 Location: north lincs Posts: 68
I stayed with the standard front to minimise understeer, but on roundabouts it does focus the attention, I would just like a little more mk2 escort than Vauxhall nova, a call to Ashcrofts looks like it’s in order. Thanks guys
| All times are GMT |
