Home > Td5 > TD5 Defender heater fault
lightning
My heater has developed a slightly unusual fault, it works fine but will only give cool air from the passenger side footwell.
In the warm setting it’s cold, and on hot it’s just warm. The screen vents are fine on both sides, as is the driver’s side footwell. I’ve looked online and others have had this fault, but nobody’s posted a solution.
Any ideas as to what needs doing to it?
Post #757940 11th Feb 2019 1:15pm
landy andy
Odd.
First things to check would be coolant level, and that heater cable is fully pulling the hot/cold lever over.
Post #757942 11th Feb 2019 1:25pm
lightning
That’s all fine.
The heater works fine through the driver’s footwell outlet, and both screen vents.
It’s just the passenger footwell.
Post #757947 11th Feb 2019 2:00pm
That suggests a problem with the mechanism within the plenum (the lower part of the dash) that diverts air to the footwell vents. It's cable operated by one of the heater levers but ISTR there's rod that links the two vent flaps, so perhaps that's come adrift at one end. Darren
Post #757951 11th Feb 2019 2:08pm
lightning
Sounds like a likely reason
How do l get to these parts, can it be accessed from inside or do l have to take out the heater from the engine bay?
Post #757956 11th Feb 2019 2:28pm
OsloBlue
Thermostat? I'm on IG: https://www.instagram.com/osloblue42/
Post #757960 11th Feb 2019 2:58pm
They're within the lower part of the dash, so it's necessary to dismantle the dash enough to gain access. I couldn't tell you how much, off the top of my head, but I suspect that it's 'most of it'. Darren
Post #757963 11th Feb 2019 3:12pm
