![]() | Home > Td5 > TD5 Defender heater fault |
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6060
Odd.
First things to check would be coolant level, and that heater cable is fully pulling the hot/cold lever over. |
| lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3553
That’s all fine.
The heater works fine through the driver’s footwell outlet, and both screen vents. It’s just the passenger footwell. |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
That suggests a problem with the mechanism within the plenum (the lower part of the dash) that diverts air to the footwell vents. It's cable operated by one of the heater levers but ISTR there's rod that links the two vent flaps, so perhaps that's come adrift at one end. Darren
Sounds like a likely reason
How do l get to these parts, can it be accessed from inside or do l have to take out the heater from the engine bay? |
| OsloBlue Member Since: 14 Jul 2018 Location: Essex Posts: 825
Thermostat? I'm on IG: https://www.instagram.com/osloblue42/
Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html ![]() |
They're within the lower part of the dash, so it's necessary to dismantle the dash enough to gain access. I couldn't tell you how much, off the top of my head, but I suspect that it's 'most of it'. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
| All times are GMT |
