Home > Td5 > Nanocom |
gtmotorsport Member Since: 29 Jun 2016 Location: Cornwall Posts: 97 |
The Nanocom will indeed do all you are asking and a bit more. I purchased on the last group buy and wouldn't be without it. It's one of those things that you hope you have little use for, but when you are able to plug in whenever and check and look at live data in order to resolve little issues it pays for itself. You also gain the benefit of plugging into the ecu for cold start if you have issues. It won't tell you what is wrong always, but if you can interpret the readings then you will go far.
10th Feb 2019 7:32pm |
Notyalc Member Since: 27 Jul 2018 Location: Northumberland Posts: 139 |
Another possible group buy underway at present.
20% off if we get to 12 takers! |
10th Feb 2019 8:32pm |
Alextd5 Member Since: 11 Feb 2017 Location: Gloucestershire Posts: 322 |
I’m in on it already ! 👍
10th Feb 2019 8:35pm |
