Home > Td5 > Nanocom
Alextd5
United Kingdom 2006 Defender 90 Td5 XS CSW Bonatti Grey
Nanocom
Will Nanocom do a security learn, code injectors and set the the 2/3 pedal tracks?
What will it and won’t do?
I’ve been told it’s the best? Obviously apart autologic,test book!
Also when you buy Nanocom will it access all systems on the defender td5 inc abs and alarm or do you have to purchase these on top?
Post #757819 10th Feb 2019 8:09pm
gtmotorsport
United Kingdom 2006 Defender 110 Td5 CSW Zermatt Silver
The Nanocom will indeed do all you are asking and a bit more. I purchased on the last group buy and wouldn't be without it. It's one of those things that you hope you have little use for, but when you are able to plug in whenever and check and look at live data in order to resolve little issues it pays for itself. You also gain the benefit of plugging into the ecu for cold start if you have issues. It won't tell you what is wrong always, but if you can interpret the readings then you will go far.
Post #757827 10th Feb 2019 8:32pm
Notyalc
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Another possible group buy underway at present.
20% off if we get to 12 takers!
Post #757853 10th Feb 2019 9:32pm
Alextd5
I’m in on it already ! 👍
Post #757856 10th Feb 2019 9:35pm
