Home > Td5 > W reg 2000 td5 tail gate wiring loom |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1746 |
I did this some time ago and it wasn't straight forward if I remember, though I was also updating the dash!
Get a copy of wiring diagram for your vehicle and then for 2002 on one and slowly look at what is different for each function.. Then methodically change as required. If you are not able to cope with this then you will definitely need someone who is. |
6th Feb 2019 8:32pm |
It's not at all straightforward as the wiring for the wiper on the later doors works on a completely different principle to the earlier ones. I undertook this exercise a little while ago on a 200tdi 90 and came up with the following though, to convert from old to new:
Click image to enlarge There's a bit more detail in the build thread HERE. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
6th Feb 2019 10:11pm |
Tim300TDIMorts Member Since: 04 Jan 2017 Location: Chandlers Ford Posts: 100 |
That’s great. I guess there isn’t an easier way? But with your diagram it should hopefully be easy enough.
6th Feb 2019 10:18pm |
I'm afraid not. The original wiring was directly switched with a permanent live to the wiper motor but the later arrangement is a switched earth set-up. The only way to convert it is as I've shown. It did work perfectly, though. Darren
6th Feb 2019 10:36pm |
Can I ask where did you get the six way connector plug from?
7th Feb 2019 3:29pm |
It was supplied by forum member, PaulMc. See here for his details: https://www.defender2.net/forum/member-paulmc.html. It was £9.95, from memory.
Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
7th Feb 2019 5:24pm |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 487 |
That was back in November 2017.
I still have these, and the price is still £9.95, which includes 1st class P&P. Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
7th Feb 2019 5:51pm |
dailysleaze Member Since: 23 May 2013 Location: United Kingdom Posts: 237 |
This should give you some pointers
https://www.landroverexpedition.com/techni...-a-300tdi/ |
7th Feb 2019 9:02pm |
That page was the basis for creating the diagram posted above. Darren
7th Feb 2019 9:19pm |
Paulmc I’ve pm’d you
7th Feb 2019 9:45pm |
Pm doesn’t seem to of worked so let me know how I can order the connector.
7th Feb 2019 10:03pm |
