Home > Td5 > W reg 2000 td5 tail gate wiring loom
Tim300TDIMorts
United Kingdom 1997 Defender 90 300 Tdi SW Epsom Green
Hi I have a W reg td5 I’ve fitted the newer style rear door and a Wiring loom. Is anyone able to tell me how to wire it to the connections show. Or if anyone is in Hampshire and could help that would be Great.
Post #756834 6th Feb 2019 8:19pm
Romadog
I did this some time ago and it wasn't straight forward if I remember, though I was also updating the dash!
Get a copy of wiring diagram for your vehicle and then for 2002 on one and slowly look at what is different for each function.. Then methodically change as required.
If you are not able to cope with this then you will definitely need someone who is.
Post #756837 6th Feb 2019 8:32pm
It's not at all straightforward as the wiring for the wiper on the later doors works on a completely different principle to the earlier ones. I undertook this exercise a little while ago on a 200tdi 90 and came up with the following though, to convert from old to new:
There's a bit more detail in the build thread HERE. Darren
Post #756880 6th Feb 2019 10:11pm
Tim300TDIMorts
That’s great. I guess there isn’t an easier way? But with your diagram it should hopefully be easy enough.
Post #756884 6th Feb 2019 10:18pm
I'm afraid not. The original wiring was directly switched with a permanent live to the wiper motor but the later arrangement is a switched earth set-up. The only way to convert it is as I've shown. It did work perfectly, though. Darren
Post #756896 6th Feb 2019 10:36pm
Tim300TDIMorts
Can I ask where did you get the six way connector plug from?
Post #757048 7th Feb 2019 3:29pm
It was supplied by forum member, PaulMc. See here for his details: https://www.defender2.net/forum/member-paulmc.html. It was £9.95, from memory.
 Darren
Post #757086 7th Feb 2019 5:24pm
PaulMc
That was back in November 2017.
I still have these, and the price is still £9.95, which includes 1st class P&P. Paul.
Post #757101 7th Feb 2019 5:51pm
dailysleaze
Post #757158 7th Feb 2019 9:02pm
That page was the basis for creating the diagram posted above. Darren
Post #757169 7th Feb 2019 9:19pm
Tim300TDIMorts
Paulmc I’ve pm’d you
Post #757180 7th Feb 2019 9:45pm
Tim300TDIMorts
Pm doesn’t seem to of worked so let me know how I can order the connector.
Post #757194 7th Feb 2019 10:03pm
