![]() | Home > Technical > Dual charge |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
You'll need to connect the two battery neg. terminals together with a suitably sized cable. Darren
| Bongo1 Member Since: 02 Nov 2018 Location: Cheshire Posts: 815
Hi yes I've done that all batteries connected properly dual charge working .
What I meant to say was the rear work light wired to the main battery . Both pos and neg . Can i disconnect the Pos wire from the main and connect to the Aux battery . And leave the neg earth connected to the main battery . Or will this confuse the dual charge system etc . My thinking earth is earth and had I of earthed at the rear and not taken the earth back to the battery box , I would only be connecting the live to the Aux batt anyway . |
Duplicated ?
In that case you'll be fine. As you say, earth is earth. Darren
Thanks I just was not sure about dual charging systems . As soon as I can find another Blue sea ST terminal I will fit one to each batt , spots to main , rear work lights etc to aux .
Again thanks , reassurance is always good . |
