Home > Technical > Dual charge
Bongo1
Dual charge
Got a dual charge system . If I run work lights off the aux batt can I connect to the aux batt Pos terminal only !!! , and leave the earth on the main battery .
I will get another fused terminal block , But do I need to get a neg terminal block also .
Reason is I can only find the Blue sea Pos blocks .
Post #755462 1st Feb 2019 2:26pm
You'll need to connect the two battery neg. terminals together with a suitably sized cable. Darren
Post #755473 1st Feb 2019 3:32pm
Bongo1
Hi yes I've done that all batteries connected properly dual charge working .
What I meant to say was the rear work light wired to the main battery . Both pos and neg .
Can i disconnect the Pos wire from the main and connect to the Aux battery . And leave the neg earth connected to the main battery .
Or will this confuse the dual charge system etc .
My thinking earth is earth and had I of earthed at the rear and not taken the earth back to the battery box , I would only be connecting the live to the Aux batt anyway .
Post #755475 1st Feb 2019 3:51pm
Bongo1
Duplicated ?
Post #755476 1st Feb 2019 3:51pm
In that case you'll be fine. As you say, earth is earth. Darren
Post #755490 1st Feb 2019 5:08pm
Bongo1
Thanks I just was not sure about dual charging systems . As soon as I can find another Blue sea ST terminal I will fit one to each batt , spots to main , rear work lights etc to aux .
Again thanks , reassurance is always good .
Post #755502 1st Feb 2019 6:13pm
