![]() | Home > Technical > Cheap Alternative to ScanGuage |
iruffell Member Since: 03 Sep 2010 Location: Marlow, Buckinghamshire Posts: 343 ![]() ![]() ![]() |
Just got one of these
![]() Click image to enlarge for £11 delivered on eBay, it's bluetooth so you can leave it plugged in and couple it to the Android Torque App (free) I thought it was worth trying out. It seems to work pretty well although the MPG figures are way out (App forum says it's a known fault and fixed in next version) |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
I did think about one of these..... but then I would have had to pay £200+ on an android phone which I wouldn't use 80% of the features so stuck to a scangauge2.
You guys will have to post up some pictures of it all ![]() Glyn ![]() ![]() |
Could yuo share the ebay link? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
http://cgi.ebay.co.uk/Bluetooth-ELM327-Fau...530wt_1010
I'll put some pictures up when I get a chance. |
Thank you mate Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1596 ![]() ![]() ![]() |
Does this work with an iPhone?
no, only android
I have found one for iPhone app is £25 and Bluetooth unit is £49.
Thought you meant Torque? which is android only. still, the cheap bluetooth obd key should work with any OS. which is it?
Found one called dash command! The app is about £24 but looks pretty powerful.
caribcat Member Since: 11 Jun 2009 Location: Anglesey Posts: 97 ![]() ![]() |
I bought the ELM 327 and am looking for an iphone ap to work with it. Right now I can't get it to show up as a possible BT connection so suspect this might not work!
mse Member Since: 06 Apr 2008 Location: UK Posts: 5102 ![]() ![]() ![]() |
Does it work with any car? Most interested for my wife's ford - but if it worked on my land rovers...bonus.
Rob where was that from? Mike |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2110 ![]() ![]() ![]() |
I bought some weeks ago this one
http://www.amazon.com/gp/product/B002PYBZJO To be connected to my laptop via USB (I prefer this way because some comments said that the bluethoot tend to lost the signal). Until now works quite well Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
The app was in the app store on the iPhone and the unit I found on eBay. Don't know if they work together tho.
