Home > Technical > Cheap Alternative to ScanGuage
iruffell
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Zambezi Silver
Just got one of these
for £11 delivered on eBay, it's bluetooth so you can leave it plugged in and couple it to the Android Torque App (free) I thought it was worth trying out.
It seems to work pretty well although the MPG figures are way out (App forum says it's a known fault and fixed in next version)
Post #70703 12th May 2011 4:25pm
BigMike
i use torque with an obd II bluetooth key. works very well. I have it on an archos 5 and have just put it on an HTC wildfire which is smaller and easier to deal with. does all the things a scangauge does and a bit more for much less money.
Post #70705 12th May 2011 4:40pm
Glynparry25
I did think about one of these..... but then I would have had to pay £200+ on an android phone which I wouldn't use 80% of the features so stuck to a scangauge2.
You guys will have to post up some pictures of it all Smile
Glyn Dog Sheep
Post #70800 13th May 2011 10:52am
dgardel
Italy
Re: Cheap Alternative to ScanGuage
Could yuo share the ebay link? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #70805 13th May 2011 11:47am
iruffell
http://cgi.ebay.co.uk/Bluetooth-ELM327-Fau...530wt_1010
I'll put some pictures up when I get a chance.
Post #70813 13th May 2011 12:55pm
dgardel
Italy
Thank you mate Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #70815 13th May 2011 1:19pm
RobKeay
Does this work with an iPhone?
Post #71079 15th May 2011 10:28pm
BigMike
no, only android
Post #71081 15th May 2011 10:50pm
RobKeay
I have found one for iPhone app is £25 and Bluetooth unit is £49.
Post #71085 15th May 2011 11:10pm
BigMike
Thought you meant Torque? which is android only. still, the cheap bluetooth obd key should work with any OS. which is it?
Post #71093 15th May 2011 11:38pm
RobKeay
Found one called dash command! The app is about £24 but looks pretty powerful.
Post #71106 16th May 2011 8:35am
caribcat
2013 Defender 110 Puma 2.2 USW Aintree Green
I bought the ELM 327 and am looking for an iphone ap to work with it. Right now I can't get it to show up as a possible BT connection so suspect this might not work!
Post #75723 13th Jun 2011 11:02pm
mse
Does it work with any car? Most interested for my wife's ford - but if it worked on my land rovers...bonus.
Rob where was that from? Mike
Post #75805 14th Jun 2011 5:10pm
Eduardo
I bought some weeks ago this one
http://www.amazon.com/gp/product/B002PYBZJO
To be connected to my laptop via USB (I prefer this way because some comments said that the bluethoot tend to lost the signal).
Until now works quite well
Cheers Eduardo
Post #75893 14th Jun 2011 9:34pm
RobKeay
The app was in the app store on the iPhone and the unit I found on eBay. Don't know if they work together tho.
Post #75914 14th Jun 2011 11:33pm
