Home > Maintenance & Modifications > Possible intercooler split
madfrankie
England 2007 Defender 90 Puma 2.4 SW Stornoway Grey
Morning Ladies and Gents,
My 2007 TDCI 90 SW has developed a loud Whooshing noise (similar to an open window)under acceleration.
and a loss of power similar to a stuck EGR. (Key off then on clears it)
I had a remap done yesterday and had the EGR switched off and blanked (Thinking it was the EGR again!!)
It would seem that this was not the case!
I had intended to have the map anyway (for the obvious reasons) and have also had the speed limiter removed.
The map has made a difference but on the test run the noise was still there.
My mechanic ( Chris @ CSK) has advised that it may be that he thinks the intercooler is split and he will check the fault codes this morning.
So after all that my Question is this....
Should I change/upgrade the intercooler anyway as an improvement to the truck?
If yes is there any particular one that you guy's would recommend?
I am not planning on upgrading the turbo (Unless that turns out to be the issue).
This is an "everyday use" truck and not intended to break the land speed record for breeze block shaped vehicles but I would like it to run as best as it can without too much witchcraft.
Input from you all welcome please.
Thanks
Frank "Of Course, Of course, I ain't asking . I'm telling!!"
Post #755196 31st Jan 2019 10:00am
benniferj
If a boost hose hasn't come off then yes there's a fair chance you want to pressure test the intercooler.
I'm a bit shocked that they would go through with performing a map on a completely compromised system though. Surely they'd be fixing that before starting to play with values and get the dyno going! How could it possibly be mapped properly if the turbo isn't sustained proper boost levels?
Post #755211 31st Jan 2019 11:13am
benniferj
Also if you upgrade the intercooler, you'd want to map it again to get the best out of it. All you will do is get cleaner EGT temp but no benefit in terms of power from a very expensive intercooler.
Post #755212 31st Jan 2019 11:14am
hank
Have you checked the boost pipe for splits? > 110 XS Double Cab
Post #755213 31st Jan 2019 11:20am
madfrankie
I am planning on going over the engine and system this evening when I get home (Having read lots of the related posts on here) so going to check coolant level , hoses, clean the MAF.
The fault codes are as below:-
DTC P0299
Turbo/Super Charger Underboost
DTC P068A
ECM/PCM Power relay de-energizing too early
DTC P0606
Control module processor internal electronics failure
any one have any clues? "Of Course, Of course, I ain't asking . I'm telling!!"
Post #755225 31st Jan 2019 12:06pm
The first thing I would check on an '07 is that the pipe from the turbo to the intercooler hasn't chafed through on the steering box, a very common fault.
Makes all manner of whistley farty noises when it goes.
Post #755227 31st Jan 2019 12:09pm
madfrankie
Added to the list.
Thank you "Of Course, Of course, I ain't asking . I'm telling!!"
Post #755232 31st Jan 2019 12:24pm
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
Re: Possible intercooler split
In answer to the original question - YES - the standard intercooler from Land Rover is O.K. but it has a history of splitting.
I upgraded to the BAS intercooler because it appeared to be properly constructed and much less likely to split. Any enhancement to torque was simply an added bonus.
I have the BAS remap as well as several other performance mods and the overall day to day driving experience is greatly enhanced.
Post #755257 31st Jan 2019 3:10pm
madfrankie
Ok Guys,
So yesterday my shiny new “Alisport” intercooler and “Alive” hoses turned up (Late in the day)
Work light at the ready, I started to remove the old one .
When I finally got the hoses off. I found this
Now I’m no mechanic “but that just ain’t right”!🤪
That would of course account for all the issues I have had.
On the upside?
I have pushed on and fitted the intercooler, blanked the EGR and had an Alive remap
Truck is like a new beast and really quick ( for a defender) on the uptake.
Really pleased.
Thank you all for your advice
Post #759213 17th Feb 2019 4:32pm
hank
Whistle > 110 XS Double Cab
Post #759332 18th Feb 2019 5:48am
madfrankie
Absolutely spot on. "Of Course, Of course, I ain't asking . I'm telling!!"
Post #759334 18th Feb 2019 7:08am
hank
On the plus side you now have some nice performance upgrades Thumbs Up > 110 XS Double Cab
Post #759338 18th Feb 2019 8:24am
madfrankie
Which I was planning on doing anyway so all good!
As for the upgrade,
I am amazed at how much extra pull the truck now has.
Back to CSK at the weekend for the new map ( taking the intercooler into account)
So fingers crossed for smooth sailing from now "Of Course, Of course, I ain't asking . I'm telling!!"
Post #759346 18th Feb 2019 8:47am
madfrankie
Also just changed the MAF & MAP sensors.
Nothing wrong with them (I think) but while I have blanked the EGR and mapped etc, Figured I would do these too.
Free to a good home if anyone wants to pay the postage?
PM me.
Going to offer them out on the "For Sale" section here as well so first come...... "Of Course, Of course, I ain't asking . I'm telling!!"
Post #759543 19th Feb 2019 9:31am
madfrankie
GONE "Of Course, Of course, I ain't asking . I'm telling!!"
Post #759550 19th Feb 2019 10:25am
