![]() | Home > Maintenance & Modifications > Possible intercooler split |
benniferj Member Since: 20 Oct 2016 Location: Basingstoke Posts: 361 ![]() ![]() ![]() |
If a boost hose hasn't come off then yes there's a fair chance you want to pressure test the intercooler.
I'm a bit shocked that they would go through with performing a map on a completely compromised system though. Surely they'd be fixing that before starting to play with values and get the dyno going! How could it possibly be mapped properly if the turbo isn't sustained proper boost levels? |
Also if you upgrade the intercooler, you'd want to map it again to get the best out of it. All you will do is get cleaner EGT temp but no benefit in terms of power from a very expensive intercooler.
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2358 ![]() ![]() ![]() |
Have you checked the boost pipe for splits? > 110 XS Double Cab
madfrankie Member Since: 10 Oct 2016 Location: Hertfordshire Posts: 356 ![]() ![]() ![]() |
I am planning on going over the engine and system this evening when I get home (Having read lots of the related posts on here) so going to check coolant level , hoses, clean the MAF.
The fault codes are as below:- DTC P0299 Turbo/Super Charger Underboost DTC P068A ECM/PCM Power relay de-energizing too early DTC P0606 Control module processor internal electronics failure any one have any clues? "Of Course, Of course, I ain't asking . I'm telling!!" |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17919 ![]() ![]() ![]() |
The first thing I would check on an '07 is that the pipe from the turbo to the intercooler hasn't chafed through on the steering box, a very common fault.
Makes all manner of whistley farty noises when it goes. |
Added to the list.
Thank you "Of Course, Of course, I ain't asking . I'm telling!!" |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 834 ![]() ![]() ![]() |
In answer to the original question - YES - the standard intercooler from Land Rover is O.K. but it has a history of splitting. I upgraded to the BAS intercooler because it appeared to be properly constructed and much less likely to split. Any enhancement to torque was simply an added bonus. I have the BAS remap as well as several other performance mods and the overall day to day driving experience is greatly enhanced. |
Ok Guys,
So yesterday my shiny new “Alisport” intercooler and “Alive” hoses turned up (Late in the day) Work light at the ready, I started to remove the old one . When I finally got the hoses off. I found this Now I’m no mechanic “but that just ain’t right”!🤪 That would of course account for all the issues I have had. On the upside? I have pushed on and fitted the intercooler, blanked the EGR and had an Alive remap Truck is like a new beast and really quick ( for a defender) on the uptake. Really pleased. Thank you all for your advice ![]() Click image to enlarge "Of Course, Of course, I ain't asking . I'm telling!!" |
Absolutely spot on. "Of Course, Of course, I ain't asking . I'm telling!!"
On the plus side you now have some nice performance upgrades
Which I was planning on doing anyway so all good!
As for the upgrade, I am amazed at how much extra pull the truck now has. Back to CSK at the weekend for the new map ( taking the intercooler into account) So fingers crossed for smooth sailing from now "Of Course, Of course, I ain't asking . I'm telling!!" |
Also just changed the MAF & MAP sensors.
Nothing wrong with them (I think) but while I have blanked the EGR and mapped etc, Figured I would do these too. Free to a good home if anyone wants to pay the postage? PM me. Going to offer them out on the "For Sale" section here as well so first come...... "Of Course, Of course, I ain't asking . I'm telling!!" |
GONE "Of Course, Of course, I ain't asking . I'm telling!!"
