![]() | Home > Maintenance & Modifications > Mantec Snorkel Installation Question. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21022 ![]() ![]() |
Why not bond the windscreen frame bracket on? Mine has been on a long time and no problems.
So did a previous member here years ago with no issues, it's a bit of of a faff but avoids drilling the frame. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ Last edited by custom90 on 26th Jan 2019 11:00pm. Edited 1 time in total |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6051 ![]() ![]() |
The hooks of the bracket goes all the way in, so A in your pic.
No, drilling the a post won’t leak. I just drilled and tapped a thread in |
Michaelkan Member Since: 19 Dec 2018 Location: Bath Posts: 149 ![]() ![]() ![]() |
When u drilled the windscreen frame did u use 5mm or 5.5mm bits. Cause mantec manual says 5mm and a YouTube video was using 5.5mm.
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3711 ![]() ![]() ![]() |
Search the site
![]() Here is my gallery with pics and instructions ![]() https://www.defender2.net/gallery/thumbnails.php?album=26 130's have feeling's as well you know ![]() |
5mm drill bit
2010Blackdefender90 Member Since: 07 Jan 2018 Location: London Posts: 562 ![]() ![]() ![]() |
I put silicon on the A Pillar bracket, and on the bracket on the air vent, if you want it water tight. |
