Home > Maintenance & Modifications > Mantec Snorkel Installation Question.
Michaelkan
United Kingdom 2011 Defender 110 Puma 2.4 SW Santorini Black
About to install the snorkel. Two question.
1. Does the bracket sitting in A Position or B position.
2. The drilling on the windscreen frame, will it leaks? I don’t see any gasket provided. Or should I add some dumdum or silicon at the back of it to prevent leaks.
Thanks.
Post #754129 26th Jan 2019 7:52pm
Why not bond the windscreen frame bracket on? Mine has been on a long time and no problems.
So did a previous member here years ago with no issues, it's a bit of of a faff but avoids drilling the frame. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #754134 26th Jan 2019 8:10pm
landy andy
The hooks of the bracket goes all the way in, so A in your pic.
No, drilling the a post won’t leak. I just drilled and tapped a thread in
Post #754166 26th Jan 2019 10:29pm
Michaelkan
When u drilled the windscreen frame did u use 5mm or 5.5mm bits. Cause mantec manual says 5mm and a YouTube video was using 5.5mm.
Post #754170 26th Jan 2019 10:33pm
AndrewS
Search the site Thumbs Up
Here is my gallery with pics and instructions Thumbs Up
https://www.defender2.net/gallery/thumbnails.php?album=26 130's have feeling's as well you know Smile
Post #754181 26th Jan 2019 11:07pm
landy andy
5mm drill bit
Post #754192 27th Jan 2019 12:04am
2010Blackdefender90
United Kingdom 2011 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
Re: Mantec Snorkel Installation Question.
Thanks.
I put silicon on the A Pillar bracket, and on the bracket on the air vent, if you want it water tight.
Post #754311 27th Jan 2019 3:41pm
