Home > Technical > Heated windscreen - :censored: or fixable?
lordackers
United Kingdom 2008 Defender 90 Puma 2.4 XS CSW Bonatti Grey
Ok so I’ve moved to heated from screen cable this afternoon so I could take a pic of the Vin number, in doing so the bloody thing fell to bits is it repairable or have I Censored it up?
Any help or advice much appreciated
Thanks
Ackers
Post #754100 26th Jan 2019 6:16pm
LR90XS2011
I'd solder it back on fairly sure it will be fine DEFENDER 90 TDCI XS,
Post #754106 26th Jan 2019 6:49pm
Balvaig
Scotland 2016 Defender 90 Puma 2.2 Landmark LE Corris Grey
Should be fixable if you can get sufficient access. You will need to solder or drill and bolt the flexible connector back onto the large spade type connector. Before starting though get a multimeter on and check for continuity from the end of the flexible connector.
Post #754107 26th Jan 2019 6:50pm
Procta
yeah you can fix that, my dad bust the rear tab on his rear window screen
https://www.amazon.co.uk/gp/product/B000AL...&psc=1 Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #754110 26th Jan 2019 6:56pm
