![]() | Home > Technical > Heated windscreen - :censored: or fixable? |
| LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3680
I'd solder it back on fairly sure it will be fine DEFENDER 90 TDCI XS,
| Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 737
Should be fixable if you can get sufficient access. You will need to solder or drill and bolt the flexible connector back onto the large spade type connector. Before starting though get a multimeter on and check for continuity from the end of the flexible connector.
| Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5374
yeah you can fix that, my dad bust the rear tab on his rear window screen
https://www.amazon.co.uk/gp/product/B000AL...&psc=1 Defender TD5 90 ---/--- Peugeot 306 HDI hatch back In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
