![]() | Home > Puma (Tdci) > Puma temperature gouges, do all lie ? |
pumajake Member Since: 11 May 2011 Location: Denmark Posts: 1 ![]() ![]() |
Hello
I have the same suspicions. Wrecked on the highway because the vacuum pump broke. The water boiled and the temperature gauge showed what it used to display. Approximately in the middle. |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2498 ![]() ![]() ![]() |
The temp dial stays in the middle from app 84º and ca.110ºC. Perhaps the customer should go on a lower gear to get more revs for the fan and less fuel injected. It works for me. Puma 110" SW
furianer Member Since: 06 Feb 2011 Location: Coomberdale Western Australia Posts: 27 ![]() ![]() |
Did the engine go in to limp mode when it happen. what kind of damage did yit do to the engine? cheers Richard |
thanks so what would be the point of having such a tem. gauge, there is no warning at all before the engine is just about going in to a melt down. There is not much chose for gears if you have to pull 3.5 to up a swiss mountain pass ![]() Could this be software related i guess the signal for the dial is feed trough the engine managment system. Hope not all TD4s are running this hot without the driver being aware of. cheers Richard |
qwert Member Since: 26 Aug 2010 Location: Switzerland Posts: 33 ![]() ![]() |
If it is an "Engine Coolant Temperature Gauge" on dash then it is either sensor or SW:
"The ECT gauge is driven by high speed CAN bus messages from the ECM." (from Workshop, page 884 ). No info in there on type of a sensor or tests/calibrations. ![]() |
No, nothing happened. I think all Pumas are the same. The other solution would be to fit a pair of extra fans. I do not know if you can set them to start at 100ºC or so. Puma 110" SW ............................................................. Earth first. Other planets later |
All moder cars have this "Strategy" on showing the engine temperature (golf, BMW, ....)
and all modern engines works "around" 95-105 °C, for a higher thermodynamic efficiency. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
More for my own interest than a particular problem, how can you tell if the viscous hub has failed? (apart from considering it an option in terms of diagnosing).
mse Member Since: 06 Apr 2008 Location: UK Posts: 5117 ![]() ![]() ![]() |
Its always been for me when the engine is warm it offers more resistance to spin than cold Mike
The manual says fuse 29 is the one - cant find a layout of the fusebox to say which is which number though. I want to just check mine as its been running a little warm
eta, found it. for anyone else its the second bank from the left, 3rd fuse down - yellow 20 amp. |
and would the engine management light not come on in the event of a failed cooling fan?
THe main fain is viscous the air con fan is electric.
It used to be the aircon fan would activate to support the viscous in an overheat condition Mike |
there is a hard core bush way of testing the visco, don t try this at home, this can be lethal !!!! take the plastic cowling of, have piece of soft timber ready 2by 4 about 1.5metr long will do, start your engine, keep it reving at around 2500rpm, keep checking temp. with a obd reader, you can hear the visco locking up as the engine heats up, careful try to slow the fan with the piece of timber, flat side to the end of the blades, if the hub is past its use by date you can bring the fan to a stop, if it is ok, it keeps spinning. this is not a advise, Just borrow a new visco from your local land lover workshop, do a testrun, obd reader in hand, see if temp. stays the same as with your unit. Richard |
Interesting, thanks. How did you attach the external temp sensors and what are they?
Actually come to think of it I dont think my fan is spinning at all which might well be the problem. |
