Home > Puma (Tdci) > Puma temperature gouges, do all lie ?
furianer
Switzerland
Good morning, just come across this.
One of my customers is running a 110 TD4 2007 Modell so far covert 185.000km. The truck is used to tow a trailer cross 3500kg most days.
On a warm one like today, high 20°, charging up a steep hill, the engine goes into limpmode, temp gouge shoots up to high for a couple of seconds then drops back to normal, engine regains power, car is up and running again.
We fitted a temp. sensor externally , hooked the car up to a obd reader, engine temp. varies from 60° to 112° land rovers temp. gauge shows just normal temperature, so you could just about cook this piece of ford engineering without knowing. Engine hits limp mode by 112°, power is back by 108°
Viscous hub was shot, replaced with a TD5 one, they are same, hope this solves the problem.
stay cool and have a nice day
Richard
Post #70495 11th May 2011 8:51am
pumajake
2007 Defender 90 Puma 2.4 HT Galway Green
Hello
I have the same suspicions. Wrecked on the highway because the vacuum pump broke. The water boiled and the temperature gauge showed what it used to display. Approximately in the middle.
Post #70502 11th May 2011 10:58am
MK
The temp dial stays in the middle from app 84º and ca.110ºC. Perhaps the customer should go on a lower gear to get more revs for the fan and less fuel injected. It works for me. Puma 110" SW
Post #70509 11th May 2011 12:00pm
furianer
Switzerland
pumajake wrote:
Hello
Did the engine go in to limp mode when it happen.
what kind of damage did yit do to the engine?
cheers Richard
Post #70511 11th May 2011 12:51pm
furianer
Switzerland
thanks
so what would be the point of having such a tem. gauge, there is no warning at all before the engine is just about going in to a melt down.
There is not much chose for gears if you have to pull 3.5 to up a swiss mountain pass Wink
Could this be software related i guess the signal for the dial is feed trough the engine managment system.
Hope not all TD4s are running this hot without the driver being aware of.
cheers Richard
Post #70512 11th May 2011 12:58pm
qwert
2015 Defender 110 Puma 2.2 Heritage Edition SW Grasmere Green
If it is an "Engine Coolant Temperature Gauge" on dash then it is either sensor or SW:
"The ECT gauge is driven by high speed CAN bus messages from the ECM."
(from Workshop, page 884 ). No info in there on type of a sensor or tests/calibrations. Sad
Post #70517 11th May 2011 2:05pm
MK
furianer wrote:
thanks
cheers Richard
No, nothing happened. I think all Pumas are the same. The other solution would be to fit a pair of extra fans. I do not know if you can set them to start at 100ºC or so. Puma 110" SW
Post #70531 11th May 2011 3:26pm
dgardel
Italy
All moder cars have this "Strategy" on showing the engine temperature (golf, BMW, ....)
and all modern engines works "around" 95-105 °C, for a higher thermodynamic efficiency. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #70548 11th May 2011 5:58pm
BigMike
More for my own interest than a particular problem, how can you tell if the viscous hub has failed? (apart from considering it an option in terms of diagnosing).
Post #70551 11th May 2011 6:15pm
mse
Its always been for me when the engine is warm it offers more resistance to spin than cold Mike
Post #70552 11th May 2011 6:21pm
BigMike
The manual says fuse 29 is the one - cant find a layout of the fusebox to say which is which number though. I want to just check mine as its been running a little warm
eta, found it. for anyone else its the second bank from the left, 3rd fuse down - yellow 20 amp.
Post #70553 11th May 2011 6:25pm
BigMike
and would the engine management light not come on in the event of a failed cooling fan?
Post #70554 11th May 2011 6:46pm
mse
THe main fain is viscous the air con fan is electric.
It used to be the aircon fan would activate to support the viscous in an overheat condition Mike
Post #70562 11th May 2011 7:14pm
furianer
Switzerland
there is a hard core bush way of testing the visco, don t try this at home, this can be lethal !!!!
take the plastic cowling of, have piece of soft timber ready 2by 4 about 1.5metr long will do, start your engine, keep it reving at around 2500rpm, keep checking temp. with a obd reader, you can hear the visco locking up as the engine heats up, careful try to slow the fan with the piece of timber, flat side to the end of the blades, if the hub is past its use by date you can bring the fan to a stop, if it is ok, it keeps spinning.
this is not a advise,
Just borrow a new visco from your local land lover workshop, do a testrun, obd reader in hand, see if temp. stays the same as with your unit.
Richard
Post #70571 11th May 2011 7:57pm
BigMike
Interesting, thanks. How did you attach the external temp sensors and what are they?
Actually come to think of it I dont think my fan is spinning at all which might well be the problem.
Post #70572 11th May 2011 7:59pm
