![]() | Home > Puma (Tdci) > Puma Injector workshop |
![]() Click image to enlarge let engine stand not running for 45 min before starting work in high presser fuel system ![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge for part number see link below https://www.lrworkshop.com/diagrams/land-r...ping_45000 check and inspect the injector having made note from witch cylinder you removed it from fit new O ring seal and copper washer check cylinder head injector port hole and copper washer seat for damage or carbon build up Refit injector back in to cylinder head .I.E. one from cylinder 1 back to cylinder one and so on ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge IF new injector are being fitted ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
