Home > Puma (Tdci) > Puma Injector workshop
dorsetsmith
let engine stand not running for 45 min before starting work in high presser fuel system Exclamation
for part number see link below
https://www.lrworkshop.com/diagrams/land-r...ping_45000
check and inspect the injector having made note from witch cylinder you removed it from fit new O ring seal and copper washer
check cylinder head injector port hole and copper washer seat for damage or carbon build up
Refit injector back in to cylinder head .I.E. one from cylinder 1 back to cylinder one and so on
IF new injector are being fitted
Post #753417 23rd Jan 2019 5:15pm
MMR1988
Germany 2008 Defender 110 Puma 2.4 SW Alaska White
May I add that it is useful to add a drop of oil at the underside of the screw head.
I'm not sure, why you recommend to wait 45 minutes before start working on the system. The only problem is the heat in my eyes. Anyway of the engine is of, the pressure in the rail system will fall to zero quite quick. I wait normaly only the time from turning of the engine until I have collected all needed tools. Maybe 5 or 10 minutes.
Don't forget to clean the injector seats within the cylinder head before reinstalling the injectors again.
Max
Post #756875 6th Feb 2019 8:59pm
