![]() | Home > Puma (Tdci) > Alive springs and Bilstein B6’s |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
Slightly off topic but can the spring isolators be purchased for a 110? 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp Roy |
LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11325 ![]() ![]() |
A good option for the front are the Discovery 2 version of the isolators as they have the turret securing bolts built in and are shaped to keep them in place:
![]() Click image to enlarge For a 110 rear, there is an isolator ring made by Old Man Emu that's designed as a trim packer for a Toyota Tundra that fits. You can get them from Devon 4x4: https://www.devon4x4.com/coil-spring-packer-10mm-36771.html Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2261 ![]() |
Hi smithy it appears there have been several ways of isolating the springs and its a bit confusing...some i think have used these on all four springs top and bottom https://www.defender2.net/gallery/albums/u...9153~0.jpg or https://rimmerbros.com/ItemImages/Large/ANR3060.JPG or https://thegippo.files.wordpress.com/2016/11/img_2502.jpg edit thanks steve i missed your post ![]() I was going to fit the discovery isolators to the front top springs and then fit these https://www.defender2.net/gallery/albums/u...010760.JPG top and bottom everywhere else.....does anyone know if this is ok? |
Basically, yes that's ok. Those castellated isolators are available at various prices on eBay and I seem to remember somebody saying that the very cheap ones were cheap for a reason. When I last bought a set, I got the Bearmach ones, which were absolutely fine.
For the Discovery 2 ones for the front, I bought these: https://www.ebay.co.uk/itm/LAND-ROVER-DISC...1438.l2649 As an aside, I know that some people have fitted isolators both top and bottom but I doubt if the second layer adds anything. Once the spring is isolated from the chassis, it can't be any more isolated by adding something at the other end. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Thanks LRA (and thanks again steve i missed your post before posting mine)I think the isolators all round were used by people who were using the lowered alive comfort springs (to regain some height back)......I know if you have isolated the top springs you will reduce the jarring to the body but logically if you fit a sheet of rubber on the bottom springs as thats what they are it must have an effect on reducing the jarring also? Every little helps and as long as it will do no harm?(any advice accepted)I will give it a go.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20889 ![]() ![]() |
LRA - Nice find on those for a 110.
![]() Nitram - No issues with mine, drives nicely. I'll never have HD springs again though they were not fitted by me but last owner and were yellow. They were horrible and all the coating came off and became rusty. Only thing I may try one day is the B6's but spring wise I'm happy with Genuine. Again, the castellated spring isolators are Genuine too on mine, but not cheap. If anyone does get to that stage it's an ideal time to replace the spring seats, fixings and Dinitrol everything with the spring out the way but of course be safe.. _\Hennessey|Venom| F5/___ ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
No, it won't do any harm and if used for the purposes of levelling then it's a useful trick. Just don't fit them for the wrong reasons. The bottom of the spring is firmly clamped to the spring seat so I just can't see how they could add anything to ride comfort. To echo Steve's post, changing springs and shocks is definitely a good time to upgrade all of the mounting hardware with galvanised equivalents. Clamps and bolts are readily available from eBay but I'd recommend Gwyn Lewis's front open shock turrets and front and rear spring seats. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
