Home > Puma (Tdci) > Hole In Piston
Page 2 of 2 <12
Julie
... This recall was related to injection points
Not related to Defenders since JLR run another firmware
https://garage.wiki/ford/transit-van/fourt...rvals.html
But, in deed, it concerned the 2.2 tdci EU5 engine, which seems to react more sensitive on mods
Post #881819 29th Jan 2021 8:45pm
Chuchi_EL Drac
Spain
I had the same problem on my 2.4 year 2010 and 95.000Km. Hole on piston No. 3.
All injectors worked OK after tested.
There is a well known problem on transit vans and there are a kit to rebuild the engine, including 4 pistons, gaskets, oil pump, etc
Post #881820 29th Jan 2021 8:47pm
Big Harold
Australia 2015 Defender 130 Puma 2.2 HCPU Alpine White
If you search the Toyota Forums here in Australia they have a dedicated one to cracked pistons.
They look remarkably similar in design and failure to the Land Rover ones.
Mark
Post #881871 30th Jan 2021 3:39am
Page 2 of 2 <12
