![]() | Home > Maintenance & Modifications > Rear sliding windows puma 2013 |
skiefang Member Since: 07 Jan 2019 Location: dudley Posts: 28 ![]() ![]() ![]() |
Can you remove the rear sliding windows and replace them in the opposite side?
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1857 ![]() ![]() ![]() |
Wont driving rain push into the 'open' end of the glass? (it will let in water like a pig!)
Keith |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4807 ![]() ![]() ![]() |
Think you probably right Keith because the glass overlap is the wrong way around and the “brush” strip won’t form a watertight seal.
Skiefang was there a specific reason for wanting to swap them round? Curious that’s all, oh and welcome to the forum. 2015 HT XS 90 2008 SVX 90 2000 XS TD5 90 |
Many thanks for your replies, I did wonder about the wind whilst driving but not the rain. The rear section will be for the 4 patterdale terriers so will have a dog cage behind the rear seats so thought it would be easier to get to to open the windows if the opening was by the rear door. Didn’t want to go through the trouble of moving them then changing them back if it didn’t work. Thank you for your welcome
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6210 ![]() ![]() ![]() |
Not that LR locks are very good anyway, but bear in mind if you did turn the windows around then someone could lean through and unlock the rear end door (unless the cage is in the way?)
