Home > Maintenance & Modifications > Rear sliding windows puma 2013
skiefang
United Kingdom 2013 Defender 110 Puma 2.2 SW Santorini Black
Can you remove the rear sliding windows and replace them in the opposite side?
Post #752283 19th Jan 2019 12:34am
skiefang
I’m not sure if I’m being clear, is there any mechanical restrictions in putting an off side rear sliding door in the near side opening and the near side into the offside space so that the opening of the windows are closer to the rear door?
Post #752394 19th Jan 2019 5:09pm
ickle
Wont driving rain push into the 'open' end of the glass? (it will let in water like a pig!)
Keith
Post #752487 19th Jan 2019 9:22pm
Sulisuli
Think you probably right Keith because the glass overlap is the wrong way around and the “brush” strip won’t form a watertight seal.
Skiefang was there a specific reason for wanting to swap them round? Curious that’s all, oh and welcome to the forum. 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #752490 19th Jan 2019 9:37pm
skiefang
Many thanks for your replies, I did wonder about the wind whilst driving but not the rain. The rear section will be for the 4 patterdale terriers so will have a dog cage behind the rear seats so thought it would be easier to get to to open the windows if the opening was by the rear door. Didn’t want to go through the trouble of moving them then changing them back if it didn’t work. Thank you for your welcome
Post #752533 20th Jan 2019 1:03am
Not that LR locks are very good anyway, but bear in mind if you did turn the windows around then someone could lean through and unlock the rear end door (unless the cage is in the way?)
Post #752559 20th Jan 2019 11:06am
