![]() | Home > My Defender > Fuji 110 LS3 build |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2947 ![]() ![]() |
Got the gear linkage adjusted to engage the tiptronic. You get a pretty average gear indicator with the shifter kit but rather than not use it i have put in somewhere I can at least see it, can get a nice digital one for the dash if I find it useful.... The tiptronic is excellent, no DCT but good changes. I find using the switch on the selector a bit awkward though as the gear stick is fully to the back and I dont want to add seat extenders so I dug out the old paddle shift kits I had from the last LS. These never really worked well as they used a bluetooth connection to the electronic shifter but I am going to try and make use of these and basically just turn it into a second switch.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 529 ![]() ![]() |
Always wondered how they worked without a clock spring! How are you planning to connect without BT?
Sorry didn’t really explain. These paddle shifters are from my last LS which had a push button gear selector and then paddles via a Bluetooth module. I now have a simple rocker resistance switch on the top on the gear stick so I plan to just replicate another switch with the paddles. Andy
Think I discovered the cause of the rough idle and occasional cut off, 10bar fuel pressure
![]() ![]() LS engines should be around 52 psi. We fitted a new high flow pump into the tank and then a new 52 psi regulator so it would seem the regulator is shot. Have a new one on the way. Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7930 ![]() ![]() ![]() |
10 bar (145 psi)!!
![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
Me too, we thought the first gauge was broken so added a bigger one which had the range. Luckily I have only run 100 miles but won’t go any further until it’s sorted. Andy
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3798 ![]() ![]() ![]() |
I might've missed it, but have we heard the sound of this V8 powered "work of art" working hard under load?
Pickles. |
not yet Pickles...need to sort out the fuel pressure! got a nice new pump and regulator so that should be me back on the road.
![]() Click image to enlarge Also decided to go down the simple route for the tiptronic, just moved the top of the gear knob, quick scan with the laser & reverse engineered it into a printed pod instead of a second cup holder, ideal location for me there. Just need to finish and paint it and then fit a new blank to the gear knob. ![]() Click image to enlarge Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
This thread is unreal, I've been involved in cars all my life, all sorts of cars, all sorts of engines/conversions etc, but I don't think I can remember such beautiful "more than professional" work, of such a complex & wide ranging nature, being carried out on a vehicle, & more particularly, where all the work has been designed, planned, & actually "done" by one person. Simply amazing.
Pickles. |
Something looks like there’s something giving birth on the centre console
Oh dear god Steve!!! Now I can't unsee that!!!
![]() ![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
Oakseywick Member Since: 20 Dec 2014 Location: Cirencester Posts: 1002 ![]() ![]() ![]() |
![]() ![]() Defender 90 Defender 110 XS Cupra 290 |
mrfirepro Member Since: 07 Nov 2020 Location: kent Posts: 235 ![]() ![]() ![]() |
Looking really good.
I need to buy the fuel system parts for my build any time now, any part numbers/advice/pics will be really useful |
![]() Got this finished and working, new blank onto the gear knob also. ![]() Click image to enlarge Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
