![]() | Home > Technical > landrover puma 2.2 fuses |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
No fuse form that but
Alarm mislock then door is left ajar, to make it sound Alarm (mislock) can be switch off, alarm unit will need to be reprogrammed |
| dcpallets Member Since: 27 Dec 2018 Location: colchester Posts: 26
i think as prev i wrote about right hand indicator does not flash either when locking and unlocking. could all be linked ?
one fuse for alarm and indicator output right and left hand
the horn and sounder unit not fuse on the same cct |
is it possible to remove alarm module?. Without screwing up anything?. to take alook inside to see if there is a dry joint for non working indicator ,
I have remover alarm unit from TD5 and had them repaired and refitted them
| All times are GMT |
