Home > Td5 > Running flat/ underpowered
Martin 01
Defender seems to be running rather flat with no sort of go in it.
Did the multimeter test on the MAF last night & seemed to be showing less than 1v at idle.
Borrowed a MAF from my friends TD5 that is running fine & fitted to mine but still seems to be running the same.
It had a new harness few months back when I serviced it & it had a new VDO fuel pump fitted few weeks ago.
Also recently cleaned the MAP sensor.
Anyone any ideas what to check for next ?
Post #749366 5th Jan 2019 3:22pm
Martin 01
Just ran a test on the MAF with multimeter & it’s showing 2v and going up when revving the engine.
Obviously my MAF was knackered.
Still doesn’t seem as lively as when I had it mapped.
Will it have gone into a learning mode whilst mine was knackered ?
Had it unplugged for couple of days to, to see if that made any difference.
Post #749384 5th Jan 2019 4:52pm
bankz5152
Learning mode?
So youve driven it with the maf disconected? Any change?
Ideally you need it pluged into diagnostics.
How flat do you mean? Could be in limp mode.
Post #749388 5th Jan 2019 5:00pm
dorsetsmith
are getting 12v supply to maf :?:
Post #749394 5th Jan 2019 5:16pm
Martin 01
Yes got 12v coming in. It’s actually around 14 when running.
Is the only way to get it out of limp mode to get a diagnostic tool plugged into it & code cleared ?
Car does have a bit more go in it but doesn’t seem to go as well as when it was remapped by Alive.
Maybe need a quick trip to go see Gary @ Alive.
Post #749408 5th Jan 2019 5:54pm
dorsetsmith
Post #749411 5th Jan 2019 6:12pm
Martin 01
Wink Thumbs Up
Post #749415 5th Jan 2019 6:47pm
drinkdrinkdrop
Wastegate actuator is worth checking with those symptoms
Post #750510 11th Jan 2019 11:57am
grafty99
+1 for checking wastegate is moving freely Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #750580 11th Jan 2019 6:52pm
Martin 01
All sorted now thanks fellas Very Happy Very Happy
Fitted new MAF sensor & now showing 2v at idle.
Rang Gary @ Alive to arrange to take it in to be looked at.
Got to Alive & they checked everything over & all seemed good until he discovered my map had been wiped from the ECU when my local guy updated my software. Local guy thought he was doing me a good deed by updating everything after sorting my 3 amigos problem out.
Anyway Gary has restored my map with more updated version & now it's running like a dream again.
Has the oooomph back & pulls strong again.
Thanks for all of your advice, much appreciated Thumbs Up
Post #750621 11th Jan 2019 9:28pm
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
A MAF is not only broken if it is dead. I had one that gave about 40% lower readings.
Reading your symptoms I don't think it is the MAF. But I don't know what else it can be. So borrow a Nanocom and do a test drive and look at the readings.
A td5 does not stay in limpmode. Everytime you start up the same problem has to be there to get in limp mode again. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #750622 11th Jan 2019 9:29pm
Martin 01
Read above my reply Roel.
Problem all sorted now with explanation above. Thumbs Up
Post #750646 11th Jan 2019 10:59pm
4RF RDS
Oh that Roel, always behind the times Rolling with laughter Bow down 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
H. L. Mencken (1880 - 1956)
Post #750658 12th Jan 2019 12:51am
roel
Looks like we were typing at the same time. Mr. Green Roel
Post #751000 13th Jan 2019 7:09pm
