Home > Puma (Tdci) > Puma revs to 1000rpm on its own?
carl_puma90
Malta 2003 Defender 90 Td5 HT Alaska White
Hi guys, I have recently changed my transfer case on my puma 90 2.4, which i also changed the speed sensor and the 3 wires. After i plugged the new speed sensor in, the defender seems to rev on its own to 1000rpm after releasing clutch and when coming to a stop. If I unplug the speed sensor, the over rev stops. does it have to do something with anti-stall?
Much appreciate your help. if anyone had the same experience on their puma.
Post #746608 20th Dec 2018 3:24pm
jst
Idle Jack keeps it at 1100rpm in 1st and rev in low. Maybe it's rewired wrong and thinks it's in low? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #746642 20th Dec 2018 6:58pm
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
+1 that sounds exactly like when the TB is in low range... Check your low/high switch (IGM500011), connector and wiring (for the record, in low range the circuit is closed) “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
2009 2.4 Puma Defender 90 SW
1979 Land Rover Series 3 88"
Post #746701 21st Dec 2018 8:53am
carl_puma90
FIXED! the high/low switch was disconnected closed circuit so it was thinking it is in low range.
Thanks for your help!!
Post #747012 23rd Dec 2018 11:00am
