![]() | Home > Puma (Tdci) > Puma revs to 1000rpm on its own? |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8440 ![]() ![]() ![]() |
Idle Jack keeps it at 1100rpm in 1st and rev in low. Maybe it's rewired wrong and thinks it's in low? Cheers
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 593 ![]() ![]() ![]() |
+1 that sounds exactly like when the TB is in low range... Check your low/high switch (IGM500011), connector and wiring (for the record, in low range the circuit is closed) “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
-- 2009 2.4 Puma Defender 90 SW 1979 Land Rover Series 3 88" |
carl_puma90 Member Since: 05 Jul 2018 Location: valletta Posts: 2 ![]() ![]() ![]() |
FIXED! the high/low switch was disconnected closed circuit so it was thinking it is in low range.
Thanks for your help!! |
