![]() | Home > Td5 > Td5 Wiper motor park switch replacement (with aircon) |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6035 ![]() ![]() |
Did mine years ago, and it was so easy I can’t remember much about it. Think I managed with just the padding removed from the dash top.
kzycnn Member Since: 24 Apr 2009 Location: Northumberland Posts: 277 ![]() ![]() ![]() |
Agree with Andy, it's a very easy job. Did mine a few months ago, expecting it to be a pig. Simply removed the dash top and there was just enough room to get to the park switch.
Tony |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 999 ![]() ![]() ![]() |
Just undo the four side screws on ether side of the dash and remove them, the ones holding the AC plenum. Remove the cetre screw or at least back it out almost to removed to take the weight of the plenum. Let it rest where it it. Gently pull the plenum down a bit, this will allow you access to the wiper dash cover screws. Remove them, change the switch. Now reverse the process. Good luck
![]() 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
Journal Photo Member Since: 15 Feb 2018 Location: Sussex Posts: 4 ![]() ![]() ![]() |
may I thank you all for all your helpful comments on this, ready steady spit on my hands and get in there.
