Home > Td5 > TD5 oil questions
lightning
TD5 oil questions
My local Land Rover specialist sold me Quantum Longlife lll oil for my Defender TD5
This is a fully synthetic 5w/30 oil but the specifications are ACEA C3 and API SN.
When l went to my motor factors to buy a 1 litre top up they looked up my vehicle and said l needed Comma XTech 5w/30
This is again a fully synthetic oil of the correct grade, but the specifications are ACEA A5/B5 and API SL CF
I looked online and these oils are different with regards to additives and something about SAPS which l didn’t understand.
Are both these oils OK for the TD5? There’s about ten versions of 5w/30 oil, each with different characteristics.
Post #744273 5th Dec 2018 10:46pm
Stu_XS
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Aintree Green
Quantum is a brand of VW Audi group. Used to be a Castrol product re-branded but more recently the contract was won by Fuchs.
https://quantumparts.co.uk/media/custom/up...eet_v4.pdf
This may shed some light - https://www.defender2.net/forum/topic64878.html Stu...
2013 Aintree Green 90 XS SW 2.2 Puma
Post #744276 5th Dec 2018 11:00pm
dorsetsmith
as both oil you have where are higher spec than ones on LR oil spec for TD5 Thumbs Up
Post #744277 5th Dec 2018 11:00pm
lightning
Land Rover recommend ACEA A1/B1 specification.
Different again to the oils l have been sold.
Will any 5w/30 oil be satisfactory? Some 5w/30 oils are “low ash” for use with engines equipped with DPF such as the TDCi 2.2 but can they be used in the TD5
Post #744313 6th Dec 2018 9:42am
windy81
Wales 1992 Defender 90 200 Tdi HT Firenze Red
the oil you have bought are over specd' and thus overpriced !! save money and get the simple stuff.
SAP means low sulfur and phosphorous whixh is irrelevvant for you since its for cars with DPF's. Again you pay a premium for this crap.... Shocked
Post #744315 6th Dec 2018 10:20am
lightning
OK so l don’t need to change the oil again then, l can leave the Quantum in, just buy the cheaper stuff next time.
Post #744347 6th Dec 2018 4:45pm
windy81
Although some expert will disagree, id say yes, leave the oil as it is.
Post #744355 6th Dec 2018 5:49pm
lightning
In the old days Castrol GTX 20w/50 “liquid engineering” did for every car. If you were really posh you might use Mobil 1 “Rally Formula” but l could never afford it.
Then came Duckhams Hypergrade
“If an engine could choose its own oil, it couldn’t choose a better oil then Duckham’s hypergrade....the engine’s choice”
Those were the days, Castrol or Duckhams. The choice was easy.
Post #744424 7th Dec 2018 1:16am
NickMc
I’d say the reason is it’ll work in so many different engines and most they probably see so they buy the one type to save/make more profit. Factors also do very good deals on the quantuam barrels to the trade. I’ve used X-tech for years in my garage and it’s my go to for Td5.
Post #744426 7th Dec 2018 1:45am
jst
Either that you have are fine and over Spencer for your engine. No need to change it. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #744451 7th Dec 2018 10:00am
