![]() | Home > Puma (Tdci) > One Shot Grease |
zephyr4 Member Since: 29 Apr 2018 Location: uk Posts: 31 ![]() |
Can I use the one shot grease on my 2007 2.4 puma or are the swivel housings non fillable.
z4 |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5987 ![]() ![]() |
I heat/warm my one shot grease before I inject. I drop it into a jug of hot water before opening it. That way it’s a much easier quicker job
I am not sure whats in it know if its already been done how do you get the grease out to renew it.
You can't basically. You can use a cable tie as a dipstick though.
If it has the one shot in will it drain out or is it to thick.
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2492 ![]() ![]() ![]() |
You would need to remove the big seal and some may flow but most of it will stick to internal parts Puma 110" SW
ok, thanks for the info.
