Home > Puma (Tdci) > One Shot Grease
zephyr4
One Shot Grease
Can I use the one shot grease on my 2007 2.4 puma or are the swivel housings non fillable.
z4
Post #743621 2nd Dec 2018 9:26pm
dorsetsmith
Yes use one shot grease on your 2007 2.4 puma
filling plug at 11 o clock can be removed with 3/8 drive ratchet
turn the steering to lock on the side that you are about to fill
remove the fill plug (which should already be out) you do this so that filling hole clears the swivel ball and the one shot grease flow in
Post #743634 2nd Dec 2018 11:04pm
landy andy
I heat/warm my one shot grease before I inject. I drop it into a jug of hot water before opening it. That way it’s a much easier quicker job Thumbs Up
Post #743644 3rd Dec 2018 12:08am
zephyr4
I am not sure whats in it know if its already been done how do you get the grease out to renew it.
Post #743681 3rd Dec 2018 11:12am
williamthedog
You can't basically. You can use a cable tie as a dipstick though.
Post #743692 3rd Dec 2018 11:40am
zephyr4
If it has the one shot in will it drain out or is it to thick.
Post #743771 3rd Dec 2018 6:09pm
MK
You would need to remove the big seal and some may flow but most of it will stick to internal parts Puma 110" SW
Post #743781 3rd Dec 2018 6:31pm
zephyr4
ok, thanks for the info.
Post #743793 3rd Dec 2018 7:12pm
