Home > Technical > High Beam Light Issue
Adam17
England 2004 Defender 110 Td5 XS CSW Java Black
Good day to you all.
So this morning on my way to work I noticed I had a light out...
Both lights work on low beam, and as you can see the 'inner side light' works.
with the lights on, If I flash the high beam it works.
But when I put it on solid high beam both low beam and high beam stop working on the driver side light.
On another note, with the lights off, when I flash the lights, it also doesn't work.
Ill be pulling the light out this eve to look for any loose connections, and checking the fuses, and checking the stalk itself...
But if you have any other info on where to start that would be gratefully received. Regards
Adam
Loving The Duchess
The Defender 110 TD5 XS
My Defender story - http://www.defender2.net/forum/topic64005.html
Post #743567 2nd Dec 2018 4:01pm
Bluest
My first port of call would be to swap the lights over to determine if it is wiring fault, or a fault with the headlght unit. 2007 110 TDCi Station Wagon XS
Post #743573 2nd Dec 2018 4:49pm
leeds
As bluest says swop lights over, if problem persists on same side that eliminates headlight fault.
Does your vehicle have dim dip relay as that is know to cause various issues.
A volt meter on the H4 connector and check voltage. LED headlights do not work below about 9 volts.
Brendan
Post #743574 2nd Dec 2018 4:59pm
Adam17
Thanks gents.
Im not sure if mine does have a dim/dip relay... I don't recal fitting/changing one when I fitted the lights about 6 months ago..
Ill change the lights over and see where im at. Thanks for the pointers... Regards
Adam
Loving The Duchess
Post #743579 2nd Dec 2018 5:15pm
Adam17
Oh and a volt meter is on my to get list hahah Regards
Adam
Loving The Duchess
Post #743580 2nd Dec 2018 5:16pm
leeds
Get a decent multimeter (which also has auto off power switch)
Check voltage at both H4 connectors
You would not have touched the dim dip bits when changing the headlights.
If you google Defender dim dip you will get information on it. Easiest way of disarming it is to swop the pink relay for a bypass relay from LR at about £30. Just watch some of the videos.
Have come across the dim dip relays causing all sorts of effects including disco style lights.
Brendan
Post #743585 2nd Dec 2018 5:55pm
Clive
The RH and LH main beam lamps are wired via separate fuses, F24 & F25 (10A) respectively, prior to the fuses they are fed from a single common connection on the steering column switch, so it seems odd that they should work differently depending on how it's switched, regardless of the condition of the switch, (a common failure point, or the dim/dip relay,) you should see the same light either working or not.
The left and right dipped beams also each have a separate fuse, F22 & F23, and again are wired to a common point on the switch.
I wonder if someone has modified the wiring in some way, maybe to add extra relays in like the Boomslang loom does.
A bit more investigation is needed here I think Confused
Post #743586 2nd Dec 2018 6:12pm
AndyT66
England 2004 Defender 90 2.5 TD XS CSW Zambezi Silver
My 2004 has me foxed as well with the dip beam full / full beam operation. Dip beam works well but when I flick the stalk forward to full beam the dip beam turns off so the road directly in front isn't lit up. However when I pull the stalk back to flash full beam the dip beam stays on and i get excellent light coverage. Could be perfectly normal?
Post #743612 2nd Dec 2018 8:44pm
Bluest
AndyT66 - That is normal operation for a H4 set up I think. 2007 110 TDCi Station Wagon XS
Post #743622 2nd Dec 2018 9:35pm
Adam17
That sounds like my issue...
So I checked the fuses with a Clarke cdm10c multimeter and they are fine, I then undone the steering column but couldnt seem to take it off so I put it back on all of a sudden my lights work..... Lol
Going to my garage tomorrow to get a new light stalk anyway 😁 as that seems to be the issue... Regards
Adam
Loving The Duchess
Post #743810 3rd Dec 2018 8:27pm
AndyT66
Sounds like a good plan Adam. Bluest thanks for confirming I just have normal light stalk. No wonder the previous owner bunged a couple of spots on the a-bar !
Post #743826 3rd Dec 2018 9:28pm
WilkoW
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Atlantis Blue
Adam, Andy
Since connecting Wipac spotlights to the main beam, without a relay (garage’s Idea, not mine) I’ve experienced the same issue. Did you solve your problems and, if so, how?
Post #747413 26th Dec 2018 6:24pm
This is entirely normal and in fact a legal requirement with H4 bulbs. You can have a maximum 55W dip beam and a 65W main, so if the dip beam didn't extinguish the resultant 120W would be illegal. The heat would also result in ridiculously short bulb life.
Post #747431 26th Dec 2018 8:10pm
Adam17
WilkoW wrote:
Adam, Andy
To sort my issue, I fitted a new light/indicator stalk... mine turned out to be a dodgy connector...
I also told lots of people I didn't recall fitting a relay - But I DID lol Laughing
If I were you though, get yourself a relay and try that first? But then the question is - would that replace current relay or be side by side?
On that note - would the garage look at it? free of charge as they fitted it without relay?? Regards
Adam
Loving The Duchess
Post #747504 27th Dec 2018 10:38am
WilkoW
Adam
Thanks for the response for which I’ll try adding a relay but as it was fitted in the UK, and I’m in Spain, I’ll have to sort it myself. However, unless it’s the increase from 55W to 100W of the new spots I don’t understand why the relay is necessary or why the stalk connectors would suddenly let go - assuming that is the problem.
Post #747917 29th Dec 2018 3:03pm
