Home > Td5 > Injector loom and parts
landy andy
Want to fit new injector loom an my new to me Td5. What is the best supplier to buy from, and also what else do I require. Rockerbox gasket, again what make, LR original parts only? Any seals on the bolts?
It’s been a few years since I’ve had the Td5, so need to refresh the memory.
Andy
Post #742183 25th Nov 2018 8:01pm
dorsetsmith
site sponsors
Dan Roberts
Parts Adviso , Duckworth Jaguar Land Rover (Market Rasen)
T: +44 (0) 1673 842101
| F: +44 (0) 1673 844410
E: Dan.Roberts@duckworth.co.uk
http://www.duckworthparts.co.uk/landrover/Engine.html
Any seals on the bolts? yes all part Cam Cover Gasket
Land Rover Defender TD5 Cam Cover Gasket
Part No.: LVP000020 from A1 p15 - 17 , 19
Injector loom Part No: AMR6103
Post #742194 25th Nov 2018 8:42pm
Alextd5
United Kingdom 2006 Defender 90 Td5 XS CSW Bonatti Grey
Genuine LR are roughly £65 or you can get the same in a britpart box OEM from ISLAND4x4 for £20+ vat part number AMR6103G (make sure it has the ‘G’ on the end) leoni, who makes most car looms. I always change the rocker box gasket also ERR7094G about £10 again OEM REINZ (15p engine)
Post #742206 25th Nov 2018 9:29pm
dorsetsmith
ERR7094G up to 2001 P10 engine Exclamation
Post #742214 25th Nov 2018 9:45pm
landy andy
Thanks all. Mine is an 06 Td5.
Post #742215 25th Nov 2018 9:47pm
Alextd5
Apologies!
Post #742221 25th Nov 2018 10:13pm
Adam17
England 2004 Defender 110 Td5 XS CSW Java Black
When I did mine I went with genuine LR. Regards
Adam
Loving The Duchess
The Defender 110 TD5 XS
My Defender story - http://www.defender2.net/forum/topic64005.html
Post #742287 26th Nov 2018 8:48am
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Fit genuine ideally otherwise you’ll be doing it again soon always replace rocker gasket as the half moon at back distorts and will leak
Don’t forget a can of electrical cleaner for loom connector and injector connectors as well as red plug on ecu 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #742288 26th Nov 2018 8:51am
Adam17
That's what my Mechanic said to me, so I listened, genuine LR all the time.. Regards
Adam
Loving The Duchess
Post #742301 26th Nov 2018 10:54am
lightning
As in the post above, the Britpart one is genuine LR in a Britpart box at 1/3 the price.
Shows how much LR make on parts.
Post #742333 26th Nov 2018 3:03pm
duckworthparts
Site Sponsor
It really isn't... https://www.facebook.com/duckworthparts
Send a paypal payment direct using this link www.paypal.me/duckworthparts
My Direct Line: 01673 849873
Email: danroberts@duckworthlandrover.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Can also supply OEM & Aftermarket parts
Post #742336 26th Nov 2018 3:25pm
Tommo
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
Use genuine Thumbs Up
I am always slightly worried when parts are re-packaged as genuine LR....personally prefer to see the LR logo Very Happy
Post #742378 26th Nov 2018 6:19pm
Alextd5
Very rare I use britpart but I’ve bought a genuine LR look in the box was the same as the the britpart (G)? Both made by ITT CANNON ! Looked identical so unless the Genuine Land Rover loom has better protection against oil I couldn’t tell the difference.
I’ve had defenders since I started driving always TD5 and fitted a new Loom every 12 months as they are so cheap, and to avoid any oil getting to the ECU and the britpart (G) has been fine.
But I agree genuine LR is my first choice normally.
Post #742698 28th Nov 2018 9:15am
BCdefender
Canada 1999 Defender 110 Td5 CSW Orkney Grey
I'm about to put in an order to duckworth parts.
Amazingly this is the second time I'm needed to do this in two years Big Cry
I have a 1999 TD5 Defender.
Are these the parts I need or is there anything else I should be ordering?
Thanks a lot.
ERR7094
GASKET - COVER
AMR6103
WIRING 1999 Defender 110
2003 P38
2007 RR SC
"And that's why it needs to be celebrated, because when the Defender goes we'll have lost this pointer to where we came from, and we're really going to miss it."
My build thread: http://www.defender2.net/forum/topic47750.html
Post #744594 7th Dec 2018 11:26pm
Justtellme
Canada 2003 Defender 110 Td5 SW Oslo Blue
duckworthparts wrote:
It really isn't...
Im always keen to learn more...could you please describe the difference between the genuine article and the OEM loom?
https://www.defender2.net/forum/topic42463.html
If it is the same item and/or manufacturer but with a different warantee, that is fine too,.....but are the components that make up the loom of a different quality as well?
I went with the genuine rocker cover gasket as I didnt want any leaks and so far so good.
Patrick
Post #744610 8th Dec 2018 4:31am
