![]() | Home > Td5 > Injector loom and parts |
site sponsors
Dan Roberts Parts Adviso , Duckworth Jaguar Land Rover (Market Rasen) T: +44 (0) 1673 842101 | F: +44 (0) 1673 844410 E: Dan.Roberts@duckworth.co.uk http://www.duckworthparts.co.uk/landrover/Engine.html Any seals on the bolts? yes all part Cam Cover Gasket Land Rover Defender TD5 Cam Cover Gasket Part No.: LVP000020 from A1 p15 - 17 , 19 Injector loom Part No: AMR6103 Last edited by dorsetsmith on 25th Nov 2018 9:48pm. Edited 1 time in total |
Alextd5 Member Since: 11 Feb 2017 Location: Gloucestershire Posts: 322 ![]() ![]() ![]() |
Genuine LR are roughly £65 or you can get the same in a britpart box OEM from ISLAND4x4 for £20+ vat part number AMR6103G (make sure it has the ‘G’ on the end) leoni, who makes most car looms. I always change the rocker box gasket also ERR7094G about £10 again OEM REINZ (15p engine)
ERR7094G up to 2001 P10 engine
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6036 ![]() ![]() |
Thanks all. Mine is an 06 Td5.
Apologies!
Adam17 Member Since: 15 May 2018 Location: Within Bedfordshire Posts: 1193 ![]() ![]() ![]() |
When I did mine I went with genuine LR. Regards
Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 ![]() ![]() ![]() |
Fit genuine ideally otherwise you’ll be doing it again soon always replace rocker gasket as the half moon at back distorts and will leak
Don’t forget a can of electrical cleaner for loom connector and injector connectors as well as red plug on ecu 2008 110 2.4 XS Utility (Hagrid) 2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
That's what my Mechanic said to me, so I listened, genuine LR all the time.. Regards
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3473 ![]() ![]() |
As in the post above, the Britpart one is genuine LR in a Britpart box at 1/3 the price.
Shows how much LR make on parts. |
duckworthparts Site Sponsor Member Since: 30 Jun 2011 Location: Market Rasen Posts: 631 ![]() ![]() |
It really isn't... https://www.facebook.com/duckworthparts Send a paypal payment direct using this link www.paypal.me/duckworthparts www.duckworthparts.co.uk My Direct Line: 01673 849873 Email: danroberts@duckworthlandrover.co.uk Supplier of Genuine Land Rover & Jaguar Parts For All Models Can also supply OEM & Aftermarket parts ![]() |
Tommo Member Since: 19 Dec 2013 Location: Leicestershire Posts: 830 ![]() ![]() ![]() |
Use genuine
![]() I am always slightly worried when parts are re-packaged as genuine LR....personally prefer to see the LR logo ![]() |
Very rare I use britpart but I’ve bought a genuine LR look in the box was the same as the the britpart (G)? Both made by ITT CANNON ! Looked identical so unless the Genuine Land Rover loom has better protection against oil I couldn’t tell the difference.
I’ve had defenders since I started driving always TD5 and fitted a new Loom every 12 months as they are so cheap, and to avoid any oil getting to the ECU and the britpart (G) has been fine. But I agree genuine LR is my first choice normally. |
BCdefender Member Since: 26 Oct 2015 Location: Nanaimo Posts: 211 ![]() ![]() ![]() |
I'm about to put in an order to duckworth parts.
Amazingly this is the second time I'm needed to do this in two years ![]() I have a 1999 TD5 Defender. Are these the parts I need or is there anything else I should be ordering? Thanks a lot. ERR7094 GASKET - COVER AMR6103 WIRING 1999 Defender 110 2003 P38 2007 RR SC "And that's why it needs to be celebrated, because when the Defender goes we'll have lost this pointer to where we came from, and we're really going to miss it." My build thread: http://www.defender2.net/forum/topic47750.html |
Justtellme Member Since: 23 Nov 2015 Location: Ottawa Posts: 310 ![]() ![]() ![]() |
Im always keen to learn more...could you please describe the difference between the genuine article and the OEM loom? https://www.defender2.net/forum/topic42463.html If it is the same item and/or manufacturer but with a different warantee, that is fine too,.....but are the components that make up the loom of a different quality as well? I went with the genuine rocker cover gasket as I didnt want any leaks and so far so good. Cheers Patrick |
