![]() | Home > Technical > Help Needed - 300tdi 110 fuel pipe route |
| jfh Member Since: 08 Jan 2014 Location: West Coast Posts: 368
No pictures at the moment, but mine runs on top of the RH chassis front to rear.
| Neilios Member Since: 01 Nov 2017 Location: Co. Durham Posts: 170
Thanks, I have that it’s the route it takes to the return at the top I am more interested in and also clip locations and pictures are always handy. Thanks.
Sorry for not posting pictures. Bit busy.
Mine is a 2006/7 model so my routing is basically the same as the TD5. |
| L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11096
Hi Neilios mine runs along the drivers side chassis rail, as i had a new chassis on Millie in 2015 i decided that i did not want any holes drilled in it, so this is what my indy did, i have had no problems what so ever with the way it has been fixed
This is coming down from the tank, it is not a tight fit, it is a big gap there for it come through .... Click image to enlarge then it runs over/through here ... Click image to enlarge then down on the chassis rail ..... Click image to enlarge Click image to enlarge then under the seat box area, but still on top of the rail ... Click image to enlarge then starting to make it's way into the engine bay ... Click image to enlarge this is going up from the rail to the injector pump .... Click image to enlarge i hope this helps you 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Perfect thanks, that’s pretty much the route I decided on today when in the garage, I am looking to get some spiral rapping material for added protection.
Great
| NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681
I find when I take the spiral stuff off it’s always full of muck. |
| All times are GMT |
