Home > Technical > Help Needed - 300tdi 110 fuel pipe route
Neilios
England 1997 Defender 110 300 Tdi HCPU Keswick Green
As per title, does anyone have a few pictures of the fuel pipe routing and where they mount to the chassis on a 110 300tdi, I did not take pictures and it’s two years since I took the Land Rover apart. Thanks in advance.
Post #741682 21st Nov 2018 11:15pm
jfh
South Africa 2007 Defender 110 300 Tdi SW Chawton White
No pictures at the moment, but mine runs on top of the RH chassis front to rear.
Post #741701 22nd Nov 2018 6:28am
Neilios
Thanks, I have that it’s the route it takes to the return at the top I am more interested in and also clip locations and pictures are always handy. Thanks.
Post #741702 22nd Nov 2018 7:03am
jfh
Sorry for not posting pictures. Bit busy.
Mine is a 2006/7 model so my routing is basically the same as the TD5.
Post #742133 25th Nov 2018 12:53pm
L110CDL
Hi Neilios mine runs along the drivers side chassis rail, as i had a new chassis on Millie in 2015 i decided that i did not want any holes drilled in it, so this is what my indy did, i have had no problems what so ever with the way it has been fixed Wink
This is coming down from the tank, it is not a tight fit, it is a big gap there for it come through ....
then it runs over/through here ...
then down on the chassis rail .....
then under the seat box area, but still on top of the rail ...
then starting to make it's way into the engine bay ...
this is going up from the rail to the injector pump ....
i hope this helps you Very Happy Clayton.
Keeper.
Post #742208 25th Nov 2018 9:33pm
Neilios
Perfect thanks, that’s pretty much the route I decided on today when in the garage, I am looking to get some spiral rapping material for added protection. Very Happy
Post #742219 25th Nov 2018 9:59pm
L110CDL
Great Thumbs Up as you can see in some of the pic's, my indy used some rubber piping for extra protection Very Happy Clayton.
Keeper.
Post #742229 25th Nov 2018 10:17pm
NickMc
I find when I take the spiral stuff off it’s always full of muck.
Post #742265 26th Nov 2018 1:12am
