Home > Maintenance & Modifications > Should I install chequer plate with a bead of silicon? |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5417 |
What ever you decide, don’t use silicone. It’s not great for external use, and will effect any painting you have done. If you wish to stick it, use a PU sealer, such as tiger seal, or even a sticks like , or builders Pu sealer.
Some I’ve stuck on other bits I haven’t bothered. You can get foam seals, but they don’t stop the crap from getting underneath anyway, and just make the CP fatter/higher. Andy. |
19th Nov 2018 11:24pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8578 |
Chequer plate sill protection? What are you trying to protect the sills from?
IMO if you want sill protection better to take existing Ali sills off and replaced with either rock sliders or rock and tree sliders Brendan |
19th Nov 2018 11:30pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3616 |
I’m tying to protect the sills from kicks and scrapes when getting in and out of the vehicle. To be clear, I don’t want to stick them on, they will be bolted in place, but wondered whether a bead of something or other would prevent any crap from ending up trapped behind.
20th Nov 2018 8:43am |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 |
As Brendan said. Remove and fit rock sliders. Then if you sell at a later date you can refit them and they're as new. That's what I have done.
20th Nov 2018 8:59am |
Rocks sliders seem like a bit of overkill just to protect the sills from scuffs from my wellies. It would be cheaper to fit new standard sills if i ever wanted to remove the chequer plate down the line.
20th Nov 2018 9:18am |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 719 |
3M helicopter tape will invisibly protect the sills from most scratches and keep the original look.Not much help though if sills are already damaged.
20th Nov 2018 9:27am |
Blacksheep Member Since: 10 Dec 2017 Location: Highlands Posts: 190 |
+1 for helicopter tape. Time is precious, waste it wisely...
Defender 90 D200 |
20th Nov 2018 9:40am |
Cheers, never thought of that. |
20th Nov 2018 9:58am |
