Home > Maintenance & Modifications > Should I install chequer plate with a bead of silicon?
Co1
I can’t decide. Am I sealing dirt and crap out, or sealing it in? I need to fit some sill protection and can’t decide if I should seal it or not? What is the common protocol?
Post #741360 19th Nov 2018 11:07pm
landy andy
What ever you decide, don’t use silicone. It’s not great for external use, and will effect any painting you have done. If you wish to stick it, use a PU sealer, such as tiger seal, or even a sticks like Censored , or builders Pu sealer.
Some I’ve stuck on other bits I haven’t bothered. You can get foam seals, but they don’t stop the crap from getting underneath anyway, and just make the CP fatter/higher.
Andy.
Post #741367 19th Nov 2018 11:24pm
leeds
Chequer plate sill protection? What are you trying to protect the sills from?
IMO if you want sill protection better to take existing Ali sills off and replaced with either rock sliders or rock and tree sliders
Brendan
Post #741370 19th Nov 2018 11:30pm
Co1
I’m tying to protect the sills from kicks and scrapes when getting in and out of the vehicle. To be clear, I don’t want to stick them on, they will be bolted in place, but wondered whether a bead of something or other would prevent any crap from ending up trapped behind.
Post #741394 20th Nov 2018 8:43am
williamthedog
As Brendan said. Remove and fit rock sliders. Then if you sell at a later date you can refit them and they're as new. That's what I have done. Thumbs Up
Post #741397 20th Nov 2018 8:59am
Co1
Rocks sliders seem like a bit of overkill just to protect the sills from scuffs from my wellies. It would be cheaper to fit new standard sills if i ever wanted to remove the chequer plate down the line.
Post #741402 20th Nov 2018 9:18am
Balvaig
3M helicopter tape will invisibly protect the sills from most scratches and keep the original look.Not much help though if sills are already damaged.
Post #741404 20th Nov 2018 9:27am
Blacksheep
+1 for helicopter tape. Thumbs Up Time is precious, waste it wisely...
Defender 90 D200
Post #741408 20th Nov 2018 9:40am
Co1
Cheers, never thought of that.
Post #741409 20th Nov 2018 9:58am
