Home > Off Topic > Two way rocker switch with illumination |
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 |
The concept is the same as you'd use for a 2 way switch in the house e.g. for the stairs:
14th Nov 2018 6:16pm |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1294 |
Yeah thanks, but I cannot seem to find illuminated two way automobile switches.
14th Nov 2018 8:22pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7683 |
Try vehicle wiring products Cheers
James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
14th Nov 2018 8:32pm |
The switch type is known as SPDT (Single Pole Double Throw). For your purpose you'll need to find a version which has terminals specifically for the indicator lamp/LED. Or mount the LED/indicator in its own bezel.
14th Nov 2018 9:01pm |
DuncanS Member Since: 07 Dec 2013 Location: Cumbria Posts: 295 |
Buy the On-Off-On Carling switches from Mud UK. Make sure they are the 10 pin variety. You can utilise Pole set 1 for the actual feed and pole set 2 for the illumination LED with a couple of jumper wires. Thats what I've done for many vehicles I've installed them into. North Cumbria Search and Rescue - Team Leader
14th Nov 2018 9:16pm |
Found an illuminated Carling switch which is On-on SPDT which is what I need ( I think).
Will see how the Mud one compares price wise |
15th Nov 2018 10:02am |
