Home > Off Topic > Two way rocker switch with illumination
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Does such a thing exist? I want to wire up my Labcraft Scenelite S18 such that I have a two way switch on/near dash and one in the rear. That way I can switch on or off from front or rear of the vehicle. However, I would like the switches lit when the light is on and unlit when switched off - is this possible?
Post #740499 14th Nov 2018 3:33pm
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
The concept is the same as you'd use for a 2 way switch in the house e.g. for the stairs:
Post #740519 14th Nov 2018 6:16pm
kmac
Yeah thanks, but I cannot seem to find illuminated two way automobile switches.
Post #740543 14th Nov 2018 8:22pm
jst
Try vehicle wiring products Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #740548 14th Nov 2018 8:32pm
Intercept
The switch type is known as SPDT (Single Pole Double Throw). For your purpose you'll need to find a version which has terminals specifically for the indicator lamp/LED. Or mount the LED/indicator in its own bezel.
Post #740561 14th Nov 2018 9:01pm
DuncanS
United Kingdom 2008 Defender 110 Puma 2.4 USW Santorini Black
Buy the On-Off-On Carling switches from Mud UK. Make sure they are the 10 pin variety. You can utilise Pole set 1 for the actual feed and pole set 2 for the illumination LED with a couple of jumper wires. Thats what I've done for many vehicles I've installed them into. North Cumbria Search and Rescue - Team Leader
Post #740565 14th Nov 2018 9:16pm
kmac
Found an illuminated Carling switch which is On-on SPDT which is what I need ( I think).
Will see how the Mud one compares price wise
Post #740646 15th Nov 2018 10:02am
