Home > Off Topic > Kitchen cabinet hinge
leeds
Does anyone know what hinge this is on a top mounted kitchen cabinet door is.
How do you adjust them? Have a tendency to just lower the door rather then holding it up.
Any help appreciated.
Thanks
Brendan
Post #739247 7th Nov 2018 8:51pm
jst
Yes, it's a really complicated looking one... Shocked Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #739250 7th Nov 2018 9:23pm
Bluest
No idea what type, but the adjustment looks to be via that hole on the bottom face to jack the lower pivot up and down. You can see the sliding scale moulded in the plastic. 2007 110 TDCi Station Wagon XS
Post #739253 7th Nov 2018 9:28pm
leeds
As far as I can see that adjustment is for how high the door goes.
My gut feeling is that it is something to do with the gas strut. Am wondering if it needs replacing?
Brendan
Post #739259 7th Nov 2018 9:36pm
Bluest
Gas struts are mega cheap on eBay even if you have to buy a couple to get the right size and strength. 2007 110 TDCi Station Wagon XS
Post #739266 7th Nov 2018 9:51pm
landy andy
Not sure what make that one is, but it will be adjustable, as it will be fitted to different size cabinets, so have to deal with a range of door weights. Possibly best to remove hinge from unit to find the way to adjust.
Post #739281 7th Nov 2018 11:38pm
landy andy
These are two possible adjustments
Post #739283 7th Nov 2018 11:41pm
lohr500
As per Brendan & Bluest, I would also suspect the strut.
If the door fits correctly, then unless the adjustment screws alter the friction on the hinge in any way, I would leave them alone.
I can't make out the part numbers on the strut from the photo, but try googling them to see if you strike lucky for a replacement.
If they are easy to swap and you have another cabinet with the same hinges that work, why not try swapping them over to prove that it is the strut/s.
Post #739300 8th Nov 2018 8:44am
Snowy90
United Kingdom 2008 Defender 90 Puma 2.4 XS CSW Fuji White
My best guess is its probably a Hafele hinge, they have a live chat thing on their website so worth a go, doesn't look that old so they will probably just replace it if its the gas strut
https://www.hafele.co.uk/en/
I maybe completely wrong of course!
Post #739319 8th Nov 2018 11:28am
ickle
Hi Brendan, I would guess the gas strut is the soft close damper.
use a black sharpie and mark across the two adjustment points in their present position so you can move it back to present, then have a twiddle!
Actual door position looks like its controlled by the slotted holes. and is there a spring inside of the aluminium section to the door?
Keith
Post #739426 8th Nov 2018 10:07pm
