![]() | Home > Maintenance & Modifications > Light bars and fitting. No holes wanted... |
Adam17 Member Since: 15 May 2018 Location: Within Bedfordshire Posts: 1193 ![]() ![]() ![]() |
Hi all.
I'd like a couple of light bars... One at the front and one at the back.. But I really don't like the idea of drilling holes in the roof. What suggestions do people have on fitting them without holes? Regards Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
Mount them on a roof rack or similar or, at the back at least, on CB aerial gutter mounts. Depends on the size of light, of course.
Routing the wiring is usually the more difficult task, and there are various options depending on how much of a compromise on aesthetics that you're willing to accept. For example, some have routed wires through the door seals, along (or inside) snorkels or used more easily replaceable parts such as the number plate plinth as the location for a drilled hole. There's no one solution that will suit everybody though. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4324 ![]() ![]() ![]() |
For roof mounted ones, I've seen people run the cable down the A pillar, either in or behind the snorkel and into the engine bay. Won't work if you don't have snorkely though. For the front, mount in front of the grille with a A bar. 2007 110 TDCi Station Wagon XS
Fitted mine on the weekend on the underneath of the rack. You could do the same with a roof bar. Wiring as said above I routed the wiring in through the corner of the door and a pillar. 👍
Thanks for the heads up peoples..
I like the idea of running the cables down the A bar. I have done the same with my cb aerial. And again with the washer hole.. ![]() Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 654 ![]() ![]() ![]() |
My rear one as mentioned is in the washer hole. The front one the wiring runs up the snorkel to the roofrack 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r |
