Home > Maintenance & Modifications > Light bars and fitting. No holes wanted...
Adam17
England 2004 Defender 110 Td5 XS CSW Java Black
Hi all.
I'd like a couple of light bars... One at the front and one at the back..
But I really don't like the idea of drilling holes in the roof. What suggestions do people have on fitting them without holes? Regards
Adam
Loving The Duchess
The Defender 110 TD5 XS
My Defender story - http://www.defender2.net/forum/topic64005.html
Post #738741 5th Nov 2018 1:07pm
Mount them on a roof rack or similar or, at the back at least, on CB aerial gutter mounts. Depends on the size of light, of course.
Routing the wiring is usually the more difficult task, and there are various options depending on how much of a compromise on aesthetics that you're willing to accept. For example, some have routed wires through the door seals, along (or inside) snorkels or used more easily replaceable parts such as the number plate plinth as the location for a drilled hole. There's no one solution that will suit everybody though. Darren
Post #738745 5th Nov 2018 1:27pm
Tommyharris
2013 Defender 90 Puma 2.2 HT Santorini Black
I thought of running the wires along the inside of the rack, then from centre at the rear down and through rear washer jet hole through a grommet (never use rear wash anyway). Just plug washer hose so it can be re instated later on.
If wire were to be unsightly, make a plate from roof rack to cover wire. The plate can be sprayed or powder coated.
It's on my list to do at some point
Post #738804 5th Nov 2018 5:43pm
Bluest
For roof mounted ones, I've seen people run the cable down the A pillar, either in or behind the snorkel and into the engine bay. Won't work if you don't have snorkely though. For the front, mount in front of the grille with a A bar. 2007 110 TDCi Station Wagon XS
Post #738805 5th Nov 2018 5:47pm
williamthedog
Fitted mine on the weekend on the underneath of the rack. You could do the same with a roof bar. Wiring as said above I routed the wiring in through the corner of the door and a pillar. 👍
Post #738809 5th Nov 2018 6:00pm
Adam17
Thanks for the heads up peoples..
I like the idea of running the cables down the A bar. I have done the same with my cb aerial.
And again with the washer hole.. Idea good thinking Regards
Adam
Loving The Duchess
Post #739104 6th Nov 2018 10:25pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
My rear one as mentioned is in the washer hole. The front one the wiring runs up the snorkel to the roofrack 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #739285 8th Nov 2018 12:19am
